Wiring on fuse panel
Old Nov 12, 2009 | 07:30 AM
Sgt. 56's Avatar
Car: 84 Z28
Engine: 454
Transmission: LT1 T56
Axle/Gears: Moser 12 Bolt Posi with 3.73 gears
Ok so I sucessfully removed the ECM without cutting any wires! Now I started to removed the harness that plugged into the ECM from under the dash and removed all the wires and noticed that a dark blue wire ran into the flasher for the turn signals with a purple one going to the ignition switch.
Since this blue wire was located on the ECM Ignition fuse 10A and the pink/black wire that was also part of the circuit was removed do I need to splice a different pink wire into that location so that my ignition switch works or will it be fine?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
stalkier
Dec 6, 2015 11:25 PM
Street Lethal
Aug 14, 2015 08:25 PM
