diagnosing a bad ground to the ECM?
Old Nov 28, 2009 | 01:26 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I connected on probe to the ground on the end of the wire by the sensor i'm testing. the other probe to the ECM ground. The Multimeter beeps saying i have continuity so is the ground ok then? Any better ways to test this ground? thanks
Old Nov 28, 2009 | 03:54 PM
Pocket's Avatar
Car: 91 Trans Am
Re: diagnosing a bad ground to the ECM?
It simply means there is continuity between the ground points which makes sense because all grounds are connected. This is a safety measure incase a ground gets broken, the rest will keep you going
To better test the ECM grounds, unplug the ECM and do a continuity test between each of the ground pins to a ground. Pull up a pinout sheet of your ECM to help you
Old Dec 3, 2009 | 05:10 PM
trueburton's Avatar
according to the schematic of the ECM i looked at, the ECM recieves it's ground from two pins. I checked the Ohms on both and they were consistant. Anything i missed?
89GTAOz
May 16, 2020 09:31 AM
dibella989
Sep 1, 2015 04:12 PM
Glowsock
Aug 31, 2015 09:01 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
