speedo swap questions!
Old Dec 2, 2009 | 10:12 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
I may be swapping my tranny out with one from a 89 or 90 iroc, both 700r4. My car is a 86 with cable speedo, i also may get the dash cluster for this car, and it has a electronic speedo. would i be able to swap the electric set into my car? whats all involved with wiring and such?
Old Dec 3, 2009 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo swap questions!
The swap of clusters from 86 to 90 would be difficult because the two are shaped much differently and because the 86 speedo is mechanical and the 90 electric as you suggest. (BTW, if the the donor car is an 89, the cluster will be the same as your 86).
Your best bet is to simply swap the speedo sleeve and driven (and perhaps drive) gears from your 86 into the 90 to keep the speedo accurate. The same would be true of the 89.
JamesC
Old Dec 3, 2009 | 02:29 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
it must be a 8, the cluster is the same shape from what i can see. i want to change the whole speedo system to electrical since if i ever put another tranny in it will be a newer one also, so i dont have to worry about changing too much over, kinks in the cable or anything like that
Old Dec 3, 2009 | 03:57 PM
JamesC's Avatar
82-89 speedos are all mechanical, 90+ electronic. The only way to go electric, as far as I know, would be to swap the entire dash or to swap in after market gauges.
JamesC
Old Dec 3, 2009 | 06:45 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
thanks for the help james! ill have to double check tomorrow on the sensor, if it is mech then thats great too!
Jorlain
Aug 24, 2022 05:11 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
