interior lights wont turn off
Old Dec 28, 2009 | 04:08 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
When I bought my car last week, the guy I bought it from said because the back hatch lock was disabled, he had to remove all the bulbs from the interior lights or they would be on all the time.
Well, I fixed the hatch today so its working normally, and the interior lights STILL won't turn off.
yes, I've checked the light switch to make sure they aren't turned on there...
Any suggestions on what to trouble shoot?
Old Dec 28, 2009 | 04:14 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: interior lights wont turn off
try the door switches, make sure they are both intact, or just unplug both of them
Old Dec 28, 2009 | 04:17 PM
58mark's Avatar
ok, i'll check that...
regarding the hatch... are the interior lights SUPPOSED to go on when the hatch is up, or is the hatch lift outside of that whole loop?
Old Dec 28, 2009 | 04:40 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
ill have to check my parts car if noone else has an answer for you, but im pretty sure its outside of that whole loop. can tell from my car as nothing is quite right around the hatch latch anymore
Old Dec 28, 2009 | 04:42 PM
58mark's Avatar
i did a search here and found the wiring diagrams... it loloks like the problem is either in a switch, or a wire is touching something it shouldn't
Old Dec 28, 2009 | 09:18 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Later model years might have the rear hatch in the circuit.
But if you've just fixed that.....
Could be a shorted light switch...i.e. the dimmer area. The dome light override may not have unlatched.
Just a thought or two.
Perhaps a bunch of testing ensues.
I'm not familiar with your setup so can't start to tell you where to test.
Old Dec 31, 2009 | 09:48 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
The most common problem is the ground wire in that system. The switches control it, and the switch frequently ends up of of adjustment.
If the ground wire gets connected to an active ground (via a short, of fubar alarm system) it will leave the lights on.
Old Dec 31, 2009 | 09:59 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
checked my 89 iroc, didnt see a switch for the lights
Old Dec 31, 2009 | 10:04 PM
58mark's Avatar
If I touch the end of the door switch with a multi meter and it's grounded, does that mean everything is ok with the door switch?
Old Dec 31, 2009 | 10:07 PM
hotbird89's Avatar
Car: 90 Trans Am
Push in the switch and test the switch from the back side where the wire connects. You shoult NOT get a reading with it pushed in when you test the wire connection.
Old Dec 31, 2009 | 10:12 PM
58mark's Avatar
ok, so i'm checking to see if the ground vanishes when the switch is pushed in, and that indicates the switch is good...
correct?
Old Dec 31, 2009 | 10:15 PM
hotbird89's Avatar
Car: 90 Trans Am
Correct, be sure to check both drivers and passengers sides.
After that, with the doors closed, pull a bulb out and test for ground. If you get a reading, that means either a switch is not properly adjusted, of there is a short.
Strange things can cause problems, like improperly adjusted window channels (the front one) puts pressure out on the door and keeps the door from pushing the switch in far enough.....
Old Jan 1, 2010 | 11:55 AM
Drew's Avatar
There's a white wire, or rather several white wires that travel through the car. If the white wire is grounded anywhere, everything on the dome light circuit will come on. It could be a bad pin switch in either door, or a bad headlight dimmer, or a pinched wire anywhere along that circuit. You'll want to find yourself a wiring diagram for your car, preferably one from a GM/Helms manual, then you can isolate each switch individually.
Old Jan 1, 2010 | 11:58 AM
58mark's Avatar
i've got a service manual on the way. I already own a 85 book, but I'm getting an 89 to make sure I don't miss anything
Old Jan 29, 2011 | 07:54 PM
58mark's Avatar
A year later, I finally got this fixed....
it ended up being a problem with a wiring harness in the dash. I had to take it to an auto electric shop to get it fixed, and it cost me $360
OUCH! but I now have interior lights...
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
