Losing Power
Old Dec 31, 2009 | 09:52 PM
92CAMARO350EDEL's Avatar
Losing Power
When ever i turn my lights on i watch my power go down and when i turn my heater on it goes down even more?? but when i turn everything off it goes back up to normal...any suggestions or known causes for this???
Old Jan 1, 2010 | 09:57 AM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
Re: Losing Power
Sounds like one of a few problems.
Problem 1: The alternator is weak and is not puting out the correct amperage. Your local parts store can test this.
Problem 2: The battery is bad, not holding a charge and resulting in voltage drop when you use high power accessories.
Problem 3: The battery cables are corroded (could be inside the jacket where it cannot be seen), resulting in high resistance which causes voltage drop.
Old Jan 1, 2010 | 10:07 AM
Re: Losing Power
ive checked both the altenator and the battery is brand new.. i will check the wires tho...thanks
Old Jan 1, 2010 | 10:09 AM
hotbird89's Avatar
Car: 90 Trans Am
Re: Losing Power
Test the wires for resistance, but be sure that you disconnect one side first, or you will get a false reading.
Old Jan 1, 2010 | 11:44 AM
Drew's Avatar
Re: Losing Power
How far down does the voltage drop? Are you going by the factory gauge or are you using a digital voltmeter? To an extent it's normal for the voltage to drop a bit.
Old Jan 1, 2010 | 07:04 PM
Re: Losing Power
i just put brand new wires on and they are good. I am going off of my factory gauges and they go from 13 to below 8
Old Jan 2, 2010 | 11:44 PM
Drew's Avatar
Re: Losing Power
Try monitoring the voltage with a DVOM, and see if the gauge is actually reading correct. Also I'd have the alternator tested a couple more times before assuming it's ok. A lot of parts stores don't know how to run their equipment. If you've got a local shop that does starter and alternator rebuilds, they'll probably be a little more proficient at testing the components.
formula_novice
Sep 5, 2015 03:58 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
