_12v hot in run but not i crank
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
from where can i get +12V that will be given only when engine is running and not powered when cranking ??
best regards
best regards
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hot Wired
You can tap into the blower circuit.
Happy Racing!
If People Drove Any Slower Theyd Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Happy Racing!
If People Drove Any Slower Theyd Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead.
Re: Hot Wired
Any 12V switched circuit is going to be engaged anytime the key is in the run position. When the key is turned to start to crank the engine, that switched circuit is typically disconnected momentarily.
What exactly are you trying to accomplish?
Re: Hot Wired
what i need to do is this:
best regards
[IMG]file:///C:/Users/WASyL/Downloads/ew7hei.gif[/IMG]
best regards
theshackle
Mar 5, 2017 06:37 PM
