under dash connector
Old Jan 4, 2010 | 05:29 PM
sprslo92's Avatar
Car: 92 z-28 vert heritage edition
Engine: LT-1
Axle/Gears: 3.08 posi
right now I'm doing a LT1 swap. I pulled the entire engine harness out with the pcm, and i am left with a connector under the dash that was part of that harness. I think it goes to the fuse box and everything in the passenger compartment that was associated with the pcm. Not sure and could use some help, if any one has a pin out for that connector or personal experience.
-Thanks
Old Jan 4, 2010 | 05:50 PM
Drew's Avatar
Re: under dash connector
You're talking about the clear connector that the engine harness plugs into under the passengers side of the dash? The pin outs aren't very specific in the manual, they tell you the wire color per cavity but that's about it. They aren't really displayed on any ONE diagram. You've got the wires for the ALDL, Park/neutral input, VSS signal, and so on. They're scattered across several diagrams.
Old Jan 5, 2010 | 03:01 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...formation.html
Has most every C100/C207
Yours is a 92 and most of my diagrams are built around the 90-92 harnesses. Each wire was traced individually through several factory diagrams to confirm the correct location and function
F.I. 57 Belair
Aug 23, 2021 01:09 AM
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
