Headlights raise when on break HELP
Old Jan 5, 2010 | 10:01 AM
92Firebirdman's Avatar
Whenever I step on the breake pedal my headlights will pop up with no lights, and go back down when my foot is off the pedal. How do I solve this problem?
Old Jan 5, 2010 | 02:32 PM
Drew's Avatar
Re: Headlights raise when on break HELP
That's a funny problem. Does it do it when the car is stopped in Park? There isn't any wiring shared between the headlights and the brake lights. Better yet, the system that operates the headlight doors is almost independent of the headlights. Are you sure the headlights don't light up for even a second? Technically the lights come on before the headlight rotates up. It matters, because if the headlight comes on for even a split second that'll signal the headlight door module to send the lights up.
Old Jan 5, 2010 | 02:37 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
not break, brake.
Old Jan 5, 2010 | 02:42 PM
Drew's Avatar
When something in the brakes breaks it becomes broken.
Old Jan 5, 2010 | 02:51 PM
I knew a typo was bound to happen sooner or later
Old Jan 5, 2010 | 07:41 PM
shakbrewer's Avatar
well sounds to me like the wires of both are touching....the brake lights and headlight wires are closely related..which means the brake lights and headlight motor wires are also close check that.
Old Jan 5, 2010 | 07:44 PM
Stephen's Avatar
Car: 87 GTA
Car alarm installed? Some how, the wiring has been tampered with. The brakes & headlight motors are totally separate circuits.
sjorgens
Oct 1, 2015 07:54 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
