NEED steering colum diagram ????
Old Jan 6, 2010 | 05:48 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Hi , looking for a drawing from a 1988 ,non airbag , steering colum drawing.
On mine ,some stuff is missing and i need to find out what .
Old Jan 6, 2010 | 06:14 PM
Drew's Avatar
Re: NEED steering colum diagram ????
Wiring diagram? Exploded diagram? Auto trans? Try this.
Old Jan 6, 2010 | 06:32 PM
THANKS, on mine #6 and #4 is missing , also #1 and #10 !
Then also, with my aftermarket MOMO steering the horn don't work. Any idea of how to fix that ?
Old Jan 6, 2010 | 06:41 PM
Drew's Avatar
1 is the spring clip that keeps the nut from backing off the shaft. It's like a snap ring, but not round.
4 is the lock plate retaining ring. It's a split spring that clips into a groove in the shaft.
6 is the turn signal cancel cam. It turns off the turn signal switch when you turn the steering wheel and the horn wire connects to it. Grounding that wire energizes the horn relay.
10 connects the turn signal switch to the multifunction lever.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
Night rider327
Sep 25, 2015 04:19 AM
