Window Help!!
Old Jan 13, 2010 | 07:48 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
Window Help!!
My driver side window has stopped working, I changed the switch and still nothing. So i got a test light, and it is getting power to the UP side of the switch, But it has NO power at the DOWN side!
Any ideas what could be wrong? I would really like to fix this lol, its a pain in the *** not having a window!
Old Jan 13, 2010 | 09:27 PM
Engine: 350 Tpi
Axle/Gears: 3.08
Re: Window Help!!
Bump
Old Jan 14, 2010 | 12:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
Window direction is determined VIA polarity to the motor.
Have you applied power directly to the motor to make sure it’s good?
If you’re getting power to the “up side” of the switch you have all the power you need.
There is a possibility the replacement switch is bad - test it with an ohmmeter.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 18, 2010 | 07:10 PM
Engine: 350 Tpi
Axle/Gears: 3.08
Re: Window Of Opportunity
Okay, so i get power all the way to the window switch, and yet it still does not go down. I even took the switch and put it on the opposite window and it worked fine. So The window Switch is Good!
So now what do i look for?
Old Jan 19, 2010 | 07:07 AM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
More than likely a burnt out window motor
Old Jan 19, 2010 | 08:49 AM
1Aauto's Avatar
Former Sponsor
Re: Window Help!!
HI Grant,
If the motor ends up being bad we sell replacement ones.
Camaro Window Motors If you have any questions about them I'd be happy to answer them for you.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
