Generator question
Old Jan 26, 2010 | 02:20 AM
vjs's Avatar
vjs
Generator question
Hi,
After I have done some mods: Mark VIII dual speed fan install, powerfull fog lights install, MSD, when the engine gets hot or after burning the wheels, drifting I got the Mark VIII fan switched on the cars revs at iddle are waiving and if the engine stops I can't start it again - battery is empty. It seams the fan is sucking out the battery and generator is just to week. I was told to change the generator to more powerful.
The question is how many Amp is stock one and to what I should go - 140 or 200 Amp?
Battery is 75 Ah.
Thank You in advance for the help.
Old Jan 26, 2010 | 09:38 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Generator question
the factory alternator puts out either 95 or 105 amps, can't remember which one. The police alternator puts out 140amps, and local parts store should have the option for stock and police or heavy duty. Also you can get an aftermarket alternator out of a summit or somewhere that sales performance parts. not many alternators charge at idle that well, if your running fans at idle.
Old Jan 26, 2010 | 09:59 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
This one is the way to go I think. 140 amp serp belt. Comes in v belt form too.
Old Jan 26, 2010 | 11:00 AM
vjs's Avatar
vjs
Thank You. I own Camaro, model of 1991. I think this one is what I need.
Old Jan 26, 2010 | 11:03 AM
Car: '91 LS6/T56/9"
Engine: LS6
Blinged out chrome, 140 amp, summit............it's a steal. The JEGS one is $170. The summit is $131.
Old Jan 26, 2010 | 11:25 AM
vjs's Avatar
vjs
One more question:
My Camaro is model of year 1991. I am located in Europe, if I buy from Summit, 131 + 90 USD for shipment + 28% of import taxes so it gets more than twice expensive. I think it should be cheaper to find some used here locally in EU. The question is what model from fits 140 Amp alternator to my Camaro?
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
