To All 1986 IROC-Z Owners, I got just 1 simple question.
Old Jan 27, 2010 | 10:00 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Can someone help me please? My fuel gage meter doesn't work. It is stuck at half tank even when the tank is full. My question is, when you turn off your 86, does the gage drop down to empty, or does it stay at the actual level of the gas in the tank? Im trying to figure out if the meter is bad or the sending unit. Thanks.
Old Jan 27, 2010 | 10:13 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: To All 1986 IROC-Z Owners, I got just 1 simple question.
should go to empty
Old Jan 27, 2010 | 10:38 PM
So then chances are that the gage is bad.
Old Jan 27, 2010 | 10:47 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
Transmission: 5 speed
Axle/Gears: 3.08 posi.
probly sending unit
Old Jan 27, 2010 | 10:49 PM
Car: 91 Trans Am
Engine: 355 TPI
could be wither or....theres only one way to find out....take it apart and get out your trusted ohm meter
Old Jan 27, 2010 | 10:50 PM
jobambjmb's Avatar
Car: 1987 IROC-Z28
Engine: L98 5.7L
sorry your right if the car is off and its still stuck there probly the meter.
Old Jan 28, 2010 | 03:52 PM
Okay. Well before I go and drop the steering column to remove my cluster, what kind of sending unit do I buy? Electrical perhaps? What size is the fuel gage meter as in diameter?
Old Jan 28, 2010 | 04:03 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
You dont need to drop your steering column to remove your cluster.
Old Jan 28, 2010 | 10:34 PM
Ohh.
Old Jan 28, 2010 | 10:45 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Chevy86, have you considered trying to just free-up the needle when you pull it out? I use a guy who restores fuel tanks and he is able to rebuild older-style sending units with all the copper wrappings. Don't know how your gauge moves the needle, but maybe it's just dirty/tired and can be saved?
Not suggesting it be sent to my guy or someone, just that it may be salvageable (sic)
Old Jan 29, 2010 | 01:03 AM
Im going to pull out my cluster to see if it's stuck. when I break the needle free, or atleast get it to go all the way down when I turn off the Camaro, I hit the message board to let you know what happens. I get back to you as soon as possible. Thanks.
corey8084
Sep 17, 2015 02:56 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Fronzizzle
Sep 8, 2015 12:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
Ian Irvine
Sep 4, 2015 08:08 AM
