Suggest a 4-pin connector to me!
Old Jan 28, 2010 | 04:35 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My reasons are a bit complicated, but basically Im hoping to wire up an aftermarket tach using some kind of plug/socket. I;ve already got another tach that's wired identically mounted in the car, but this one is much nicer, and due to that and some other reasons, I'd much rather snip the wires and add a connector than rewire it.
But Im no electrician, I've never messed around with making any kind of socketed connector. Anyone know of any 4-pin connector that woudl be good for this? Would prefer something smaller, but something that I can actually put together with regular tools, or if I need a special tool for it, at least that it'd be cheap. I dont really know much about what's available, but it's the most elegant solution for me I think. So if anyone could point me in the right direction that'd be awesome.
Old Jan 28, 2010 | 04:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Suggest a 4-pin connector to me!
Go to Radio Shack or similar.Have a multitude of connectors that will do what you want.Even some of the ones intended for audio equip might suit
Old Jan 29, 2010 | 10:08 AM
Pocket's Avatar
Car: 91 Trans Am
Not sure what you're asking
An inline connector to be able to quickly remove the new electronics would be simple. Find a generic 4 pin weather pack from a parts store, radioshack (maybe), or the easiest being a used one from a JY car
For a specific connector that plugs into the tach, ask the manufacturer
Old Jan 29, 2010 | 03:59 PM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
4-pin weather pack for automotive applications. You would probably need to crimp pins.
or
4-pin connector from a computer (interior use only) You could get away with buying this cheap extension which contains both male and female plugs, cut it in half and connect to the wires.
Old Jan 29, 2010 | 07:49 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
just go to the junkyard and look around different engine bays from different cars. I've grabbed a few for the same reason. I normally don't hardwire interior accessories so I can quick disconnect them during disassembly...
ChristinaMarie
Sep 11, 2015 06:28 PM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
