cc hei distributor
Old Feb 20, 2010 | 11:07 PM
bradwulf20's Avatar
Car: 91 camaro RS
Engine: 305 carbeurated
cc hei distributor
i have a 91 rs was a 3.1 car i am dropping in a non cc carb 305 but the motor i have has a cc hei distributor on it i was hoping to use and was wondering if this will work or if i am going to have any problems with it?
Old Feb 21, 2010 | 01:23 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: cc hei distributor
Yes, you'll have problems, like no timing advance. If you're going non-computer, you need a vacuum advance distributor.
Old Feb 21, 2010 | 07:28 PM
bradwulf20's Avatar
Car: 91 camaro RS
the distributor has a vacum advance and also has the 4 wire plug coming off it that is attatched to the module
Old Feb 21, 2010 | 08:54 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, if it has a vacuum advance diaphragm, then it's not a CC distributor and should work fine. It sounds like it's the older style HEI. While not computer controlled, it is still electronic, which is what the ignition module and wires are for. Instead of using breaker points, the ignition module determines when to fire the coil.
Old Feb 22, 2010 | 06:33 PM
bradwulf20's Avatar
Car: 91 camaro RS
so what do i need to do with those 4 wires ?
Old Feb 22, 2010 | 07:07 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, 2 of them will be coil power, one will be the tach wire, I'm not sure what the 4th would be. What colors are the wires? Can you post a pic of the distributor/wires?
Old Feb 22, 2010 | 08:24 PM
bradwulf20's Avatar
Car: 91 camaro RS
i will get pictures later but it has a plug that looks almost like a trailer light plug comes off between dist. and cap also has a red wire wich i know is power and a white wire wich i know is the tach wire that come out of the top back side of the cap but this is a totally sepparate plug
Old Feb 22, 2010 | 08:42 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Hmm, are you sure it's a vacuum advance distributor then? The CC one (non-vacuum) looks like this, and has a 4-pin plug.
Old Feb 22, 2010 | 09:34 PM
bradwulf20's Avatar
Car: 91 camaro RS
it looks kinda like that but has a vacum diaphram and the 4 wire plug is about twice that size
Old Feb 22, 2010 | 10:23 PM
bradwulf20's Avatar
Car: 91 camaro RS
Old Feb 22, 2010 | 10:24 PM
bradwulf20's Avatar
Car: 91 camaro RS
Old Feb 22, 2010 | 10:25 PM
bradwulf20's Avatar
Car: 91 camaro RS
looks something like that
Old Feb 23, 2010 | 12:04 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I searched around google some, since I haven't ever seen a 5-pin non-CC ignition module. The only info I could find says that the extra wire is for a knock sensor, which would retard the timing on knock. Any idea what the distributor came out of?
Old Feb 23, 2010 | 07:32 PM
bradwulf20's Avatar
Car: 91 camaro RS
i do not know what it is out of but the vacum diaphram should take care of the timing advance so what would the 4 wires do other than knock sensor wich i am not hooking up
Old Feb 23, 2010 | 10:31 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
With or without the vacuum diaphram the timing will retard with no knock sensor.
Old Feb 24, 2010 | 10:32 PM
bradwulf20's Avatar
Car: 91 camaro RS
so what do i do with the four wire plug ? do i need it ?
Old Feb 26, 2010 | 08:48 PM
bradwulf20's Avatar
Car: 91 camaro RS
can anyone help
Old Feb 27, 2010 | 05:00 PM
Car: 1990 RS Camaro
Engine: 305 TBI
The plug for your distributor needs to be adapted to fit you wiring harness for your ecu.
You find the plug on the harness that should go to a distributor, find out which wire is which, 1 would be for knock sensor, 1 or 2 would be for tps signal and Im not sure what the last one would be for.
Once you know which wire is which, cut the old plug off the harness and wire in the new plug. Its kind of hard to help if you dont know where the distributor is from.
Im not very good at wiring and electrical, this is just from my brief knowledge. Someone smart should chime in and help this guy
Old Mar 3, 2010 | 10:06 PM
bradwulf20's Avatar
Car: 91 camaro RS
thanks for all the great info i just gave up and bought a different distributor from a friend of mine got a acell super coil
Old Jun 11, 2010 | 02:57 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
there are CC EST HEi dizzies in 1982 trucks they do have vacuum advance
im tired of ppl claiming that no CC HEI had vacuum advance when in fact many were made and i hve one sitting here right now,
form 1982 K10 pickuyp with 305 and EST system and E4ME carb
look it up for yourself
some caprice wagons were EST with vac advance also...
1103465 is the distrib number
they also have weights too
and the 5 pin module for EST system
1103460 is the more common one and yes it has no vac advance,
but just because you havent ever senen a 465 hei doesnt mean they dont exist
whoever started this CC distributorrs never had vac advance crap is a moron.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
