1990 camaro interior lights dont work in convertible when door opens help
Old Mar 7, 2010 | 11:12 AM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
the interior lights dont come on when door opens ,no power to the tan or white wires in door jams but fuse is good and have power going to the orange wire to the rear view mirror and cig lighter and dash all works the mirror entry lights should light up when doors open but dont any ideas this is a converitilbe
Old Mar 7, 2010 | 11:23 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: 1990 camaro interior lights dont work in convertible when door opens help
maybe the door jamb switches are bad.
Old Mar 8, 2010 | 08:47 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Convertible Is Not Lighter
Do the interior lights come on when you try the “courtesy” switch on the headlight switch?
Anyway there is a broken connection in the white wire near the connector located behind the left shroud.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Mar 8, 2010 | 06:39 PM
Engine: 350 tpi
Transmission: auto
no the courtesy light does not tight up the riew when you turh the headlight switch to opperate and the white wire runs into the harness then dissappears into the wire warped with duck tape
Old Mar 9, 2010 | 03:29 PM
NINÅ's Avatar
Transmission: 765R4
Take a look at the connector as noted in post 3.
It’s a 4 pin unit.
Happy Racing!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
