swap almost done ign wire question
Old Mar 13, 2010 | 10:54 AM
tcgmac's Avatar
Car: 88 iroc
Engine: 350 bored .40 reman vortec heads
ok my swap is just about come to the end here is what i would like to know. Can I wire my one fan and the intank fuel pump to the ign wire that runs to the dist. or should i find a diff. way of doing this. 88 iroc went from 305 tpi to carbed 350 bored .40 over, vortec heads that will handle upto a .600 lift cam. i only have a .510 lift. 650 double pump holley
Old Mar 13, 2010 | 01:53 PM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Re: swap almost done ign wire question
I wouldn't run any additional loads off my distributor's ignition wire. You can run the fan off the white wire that feeds the old fan relay, but the fan will run as soon as you turn the ignition on. You should be able to still use your original fan relay if you just feed the green/white wire directly to the thermal switch in your head rather than through the ECM.
Sorry but don't know enough about the fuel pump issue. Mine has a mechanical fuel pump.
Old Mar 15, 2010 | 08:33 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuel Rule
It sounds like you no longer have the ECM.
There’s no reason to have the fan constantly running therefore you should use
1988GTA500HP’s advice.
For the fuel pump you can tie it to the ignition wire however make sure you use a relay.
Happy Racing!
Round Out Your Life, Drive Oval Tracks
midge54
Sep 2, 2020 07:13 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
