84 camaro ecm
Old Mar 15, 2010 | 12:20 AM
berlinettajake's Avatar
Car: 84 camaro berlinetta
Engine: 383 stroker Bored .40 over
Transmission: th-400 hughes 2500 Stall
Axle/Gears: moser axles 3.73 gears
84 camaro ecm
Ok i have a 84 camaro berlinetta and recently started to just die while running. everything shuts off, complete electrical shutdown no power anywhere and it will come back up after awhile. dont know whats going on im geussing its somthing in the ecm? What exactly does that control? can i eliminate it? i dont have anything really left to control on the engine theres no elec. to carb no A/C Blower Motor anything like that. Any help would be great
Old Mar 15, 2010 | 08:54 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sour Power
Your problem is immediately after the battery.
The most likely cause is a bad connection at the solenoid.
Remove the cables there, clean them, replace them, and you should be good2go.
Happy Racing!
Round Out Your Life, Drive Oval Tracks
Old Mar 16, 2010 | 12:09 AM
Re: Sour Power
awesome il try that out thanks
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
