HVAC running after ignition off
Old Mar 20, 2010 | 06:01 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
so i got home today and found my vents were still blowing full speed when I turned my car off, i even double checked to make sure the key was in lock position. I turned the hvac to off but it just kicked on the ac at full blast. turned the fan to low and it killed it. Any ideas on what might cause this.
-ps I know cooling fans may run after car is off but these are not the cooling fans.
Old Mar 21, 2010 | 01:08 AM
MPIpowered4x4's Avatar
Re: HVAC running after ignition off
Check to see if the relay is sticking closed. unplug the relay if it goes out, it might be the problem. swap relays with a known good one
BRoss99
Aug 10, 2025 05:08 PM
Fast355
Dec 2, 2016 06:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
