headlight/foglight harness
Old Mar 22, 2010 | 05:41 AM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
A friend of mine has a 88 headlight/foglight wiring harness for 20 bucks, is it compatible with my 91 harness? just wanna make sure b4 i buy it and hack mine up
Old Mar 22, 2010 | 11:36 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Re: headlight/foglight harness
From what I've read 88-92 are basically the same can someone confirm this for me thanks
Old Mar 27, 2010 | 09:19 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
BUMP..
Old Mar 27, 2010 | 05:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you are trying to add fogs to a non-foglight car - the problem I found was that somewhere in the bulkhead connector the foglight wiring just stops - a dead end - all the switch wiring is in the panel, but it gets lost before it makes it out under the hood.
I added fogs to my 1992 RS by using the stock switch, wiring 12v+ to the switch and a ground - then wiring a simple wire to underhood from the switch, that activates a relay to run my fogs directly off the battery. It was simple and quick, and I don't have to worry about having high amp wiring running from inside to outside since the fogs run directly off battery through the relay.
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
