window spring + gauge problem
Old Apr 22, 2010 | 02:03 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
this week I totally redid my door.
I did the window motors
I did the doorrubbers ( complete softsealed them )
I did the door lock actuators ( I made them work again )
I did Isolated the doors again.
I put new locks in the doors
but on my passenger side door when I did the window, a spring fell out.
the window works now, but it goes up slowly ( could be because of the new rubbers )
but if its the spring that needs to be back, where do I put it in again and how.
second question, I got a nordskog fuel gauge, but it keeps displaying random numbers ( looks like something that can be used in LOST )
it even blacks out sometimes or displays FF.
does anyone know what is going in with the gauge ?
Old Apr 22, 2010 | 03:11 PM
NINĊ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Acts Fuelishly
FF means FULL.
You need an anti-slosh circuit to quell the numbers bouncing all over the place.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Apr 22, 2010 | 03:17 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: Gage Acts Fuelishly
but it isnt full, its at 70% and the random numbers go from 11 to 14 to 89 to 99 to FF blackout etc.
Old Apr 22, 2010 | 03:34 PM
NINĊ's Avatar
Transmission: 765R4
Gage Acts Fuelishly
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the removed sender wire so it can’t short.
Use a potentiometer with a value of 90Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a 0-99 then FF.
Is it in warrantee?
Happy Racing!
Old Apr 22, 2010 | 03:40 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: window spring + gauge problem
ik you put the sensor wire to ground it should read 0 fuel ( 0 ohm )
but even that he doesnt do right
oh yes, its only a week old bought it trough summit.
Old Apr 22, 2010 | 09:26 PM
ĦMR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
Regarding the spring. https://www.thirdgen.org/forums/body...pring-r-i.html
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
