toggles for headlights?
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
so im thinking about getting rid of the factory head light switch because its mount is broken and im looking to have a little more custom look to the interior so im thinking of putting in 2 seperate toggle switches for the head lights one for high one for low how would i go about wiring that?
Re: toggles for headlights?
Are you sure two toggle switches are going to give you this "custom" look? You can add two toggle switches that aren't wired to anything if you think that customizes it. Don't take me wrong, I'm not trying to chide you. You have to remember, your dimmer switch is usually involved in a headlight switch. I'd recommend you just fix the stock one and find some other way to get this custom look. You can probably find a switch mount at a junkyard pretty cheap
Engine: 3.1 v6
ok i geuss i could have explained it a little bit better the po also cut the wires for the high beams im not sure why but also the switch is messed up and broken now i figure because im short on money and i love doing things myself i would put in toggle switches because it will give me the "industrial" look that im going with on this particular car. any feed back on how to go about doing this would be appreciated greatly thanks.
