HELP Can't Get Fuel Pump 2 Run Without running a hot wire to Relay!!!
Old Apr 28, 2010 | 11:27 PM
TRANSAMCRAZY's Avatar
Car: 87 T/A,92 T/A,
Engine: 406TPI,355TPI,
Transmission: 700R4 for all
Axle/Gears: 4.11,3.23,
I don't know what happened, but my fuel pump is good, there is power to 1 wire on relay, but no fuel pump!!! replaced fuel pump, replaced relay still no power, u can run a hot to the middle wire on the relay AND BINGO THE CAR WILL START what could cause this? the car is an 87 trans am had this problem when i parked it in 2006 since then I put a 434 in it and I am still running a TPI (all aftermarket) could it be the ignition switch on the columm? replaced coluum and it still does it. car does not have VATS or alarm or remote start. Car is a limited # run for 87 and wanna keep it kinda stock would hate to carb it can anyone HELP!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 29, 2010 | 12:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Just Fuelin’ Around
If you retained the ECM, the problem is: the pump relay is not receiving the priming signal.
To test it, connect a test light
(for testing for voltage, not a continuity tester) to terminal A1 of the EMC and ground.
Turn the key to the RUN position.
Does the test light go on for ~2 seconds?
Happy Racing!
Just One Of Them Racin’ Deals
Old Apr 29, 2010 | 10:37 PM
Car: 87 T/A,92 T/A,
Re: Just Fuelin’ Around
ty
Old Sep 8, 2010 | 10:36 AM
TheJoeY88's Avatar
ever find a fix to this problem?
Old Sep 8, 2010 | 01:03 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: HELP Can't Get Fuel Pump 2 Run Without running a hot wire to Relay!!!
if not, check your C207 connector on the passenger side; there's a few of the fuel pump relay wires going through it. you may have a bad connection
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
