Swapping 95 Caprice Squad LT1
Old May 8, 2010 | 01:18 PM
Javelin74's Avatar
I am swapping my 95 Caprice LT1 into my 91 Z28 Convert (305 TPI). I am having trouble finding the correct info on wire swap between the two. Could anyone tell me if I should convert the wiring harness with the LT1 or use the Camaro wiring harness?? Thanks for all suggestions in advance!
Old May 11, 2010 | 09:40 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Swapping 95 Caprice Squad LT1
You need both for a successful marriage
The 3rd gen harness will be stripped to gauges, IGN, starter, relay functions only and the LT1 harness stripped to engine/trans management
Read the harness threads in the LS1 swap sticky for a detailed explanation of the procedures required. Dont be afraid of the LS1 titles because the job is the same for LT1s
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
