Very hot rear hatch motor--normal?
Old May 19, 2010 | 09:07 AM
florida_gators's Avatar
Car: 1990 Firebird
I have an original hatch motor I just replaced the nylon guides to. I opened and closed the hatch a couple of times after the repair, and I noticed the hatch motor housing is VERY hot. No steam coming off, but you couldn't hold a finger on it for more than a second or so. Before checking the guides to make sure I shaved them down enough (which I'm sure I have...I spent all afternoon fine tuning them), I unplugged everything from the hatch motor and let it sit overnight. It was cool this morning. Without operating the mechanism, I crawled through the driver door into the hatch area and plugged everything back in. Within minutes it was very hot again. It works fine, but is this heat normal, or is the motor broken and burning itself up? Thanks!
Old May 19, 2010 | 09:08 AM
Twin_Turbo's Avatar
Re: Very hot rear hatch motor--normal?
No it's not, something's not right
Old May 19, 2010 | 09:18 AM
Car: 1990 Firebird
Thanks for the quick reply. All I can think is that I may have gotten some WD-40 inside the motor's wiring plug connector when cleaning it, but it has since dried and wouldn't cause this anyway, would it? Just wondering before I buy a new motor from Top Down.
Old May 19, 2010 | 09:29 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
if its hot sounds like its not shutting off.
Old May 19, 2010 | 09:35 AM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Hey any ideas on why a engine may be too hot? Because recently I just check out my fluids to make its full and found out its like piping hot!! Like the engine is the sun or sumthing. btw car is 85 camaro with new engine put in it. (V8)
Old May 19, 2010 | 09:37 AM
Twin_Turbo's Avatar
retarded timing?
Old May 19, 2010 | 09:56 AM
Car: 1990 Firebird
Have you checked the thermostat?
Old May 19, 2010 | 03:55 PM
FryeDaddy's Avatar
lol i cant even check that because my thermostat and oil dont work =S but i would like to kn what i need to do if it is too hot for the engine, and since i live in texas summer is only gonna get hotter which isnt good if my engine is hot the way it is. Help?
Old May 19, 2010 | 04:08 PM
Car: 1990 Firebird
It may be a good idea to replace your thermostat anyway to make sure your engine doesn't get over 160 degrees. (I'm assuming you mean your dash gage is broken?) If your thermostat is broken the cooling system isn't kicking in at the right time. I haven't bought one in a while but they should be around $15? Cheap solution and even if this isn't the right fix at least you know this isn't the problem.
Old May 19, 2010 | 04:20 PM
FryeDaddy's Avatar
Yes I know i need to change the thermo, but its kinda common sense that you know something wrong like scorching hot engine. But according what you may be saying are you saying my cooling system isnt working properly?
Old May 21, 2010 | 12:41 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I thought this thread was about a hatch motor getting hot, not an engine.
Either the hatch motor isnt shutting off as suggested, or maybe an internal short?
Old May 22, 2010 | 02:31 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Nope, not normal. The guides are binding causing too much strain on the motor. Sand the guides until they fit your channels easily. Start with just two, inner or outer. Insert just two, slice the latch mechanism up and down by hand (without the motor attached) then remove them and sand where the dark spots or lines are. The dark areas indicate where they are making contact. Once you have that pair sliding easily remove them and work on the other pair of guides. Then install all four and repeat. The latch assy must slide easily in the channels.
Lon
Old Jan 24, 2024 | 07:55 AM
hassgrant's Avatar
Car: '91 Z28 305 TPI
Transmission: Manual
I just had this same problem, yesterday. I was fine tuning my amp and smelled what I call an electrical burn smell. I thought some wires from the amp or capacitor came loose while moving around box and were touching. Come to find out it was my hatch motor was scorching hot. Not sure why, haven't had any problems with hatch motor recently. I unplugged the battery for now until I can figure it out. Any suggestions?
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
