Fuel Tank Sending Unit electrical plug on the body
Old May 23, 2010 | 09:59 PM
libolt's Avatar
Car: 1991 Trans Am
I have put a new fuel pump and sending unit in my tank, got everything back in and bolted up. Then I went to connect the new sending unit's connector to the plug that is on the body and found that the plug is damaged. I've already pulled up part of the carpet and found where it's at. Where would I get a replacement plug and what would it be called?
I've tried connecting the old sending unit to the plug and it doesn't work either.
Old May 24, 2010 | 12:10 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Fuel Tank Sending Unit electrical plug on the body
I have no idea if theyre still being made or if you can get a repro, but a 3rd gen in a junk yard should have it.
Old May 24, 2010 | 10:38 PM
libolt's Avatar
Car: 1991 Trans Am
Thanks for the help. I'm just going to put a new matching set of weatherpack connectors on the sending unit and the body wiring harness.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
