digital tach wont light up
Old May 31, 2010 | 12:00 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
The tach doesnt light up like the rest of the dash, it also reads the incorrect rpm. Ive searched but didnt find any reason why only the tach wouldnt light up brightly. Any ideas?
Old Jun 3, 2010 | 12:23 AM
JT's Avatar
JT
Community Administrator
Re: digital tach wont light up
So I understand the tach does appear to work, as you can see the "segments", it's just not brightly lit anymore?
If so, it's most likely a burned out bulb. The digital cluster uses a few illumination bulbs to help brighten the display and make it readable.
You probably know that in a conventional dash, there's illumination bulbs that are used at night to light up the cluster. The digital cluster uses those same bulbs, however, they're on all the time and controlled by the thumb wheel near the headlight switch. There's one illumination bulb right behind the tachometer, and thus, I would suspect it's burned out.
Old Jun 3, 2010 | 08:56 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks for the info JT, it also doesnt read properly but from what Ive reasearched Ill have to solder in a resister.
Pilotrick50
Sep 2, 2015 12:48 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Omega
Aug 10, 2015 12:46 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
