Edit: Power door locks relay location
Old Jun 10, 2010 | 02:10 AM
andreas's Avatar
Car: Firebird 82 S/E
Engine: 383cui, alu heads, etc
Axle/Gears: 4th gen, 3:43
Hello guys!
I would appreciate if you could tell me exactly where the power windows relay is located. I know it should be somewhere under the driver side dash.
I'm converting to power windows and locks and are using a stock wiring harness for my 82 firebird but the shop manual don't tell me where it should be placed.
I also wonder how the cables from the relay towards the buttons is routed, under the seat or under the center console?
I'll give you a blurry picture of the relay
Cheers!
Attached Thumbnails Edit: Power door locks relay location-pwrelay.jpg
Old Jun 10, 2010 | 11:25 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Power window relay location
Never been into the relay - but the wiring is routed under the center console in my 1992.
Old Jun 10, 2010 | 02:08 PM
andreas's Avatar
Thanks!
One step closer.
It might be placed next to the flasher relay under the dash then.
Old Jun 30, 2010 | 02:57 AM
andreas's Avatar
I messed up a bit. Its the power door locks relay Im talking about.
I figured out it should be bolted somewhere under the driver side kick panel but can't find any picture in the shop manual or anywere else of its exactly position. If somebody feel for taking a picture and upload I would be really greatful. Its always better to place things where they were ment to be.
Thanks!
/ Andreas
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
