how many volts should the cooling fan switch be getting?
Old Jun 14, 2010 | 06:03 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: Stock 3.42
how many volts should the cooling fan switch, located on the passengers side head, be getting ? Mine reads around 12 volts. thanks in advance
Old Jun 14, 2010 | 08:09 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: how many volts should the cooling fan switch be getting?
12v is right.
Old Jun 14, 2010 | 08:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Cooling fan switch doesn't get 12v does it? It's the ground for the fan relay - if you ground the wire for it, the fan comes on. I guess if it's grounded it's getting 12v maybe - but it shouldn't have voltage on it.
Old Jun 14, 2010 | 08:51 PM
travis401's Avatar
Car: 91 Camaro RS
With it grounded it will be getting 12v.
Old Jun 14, 2010 | 09:15 PM
Car: 1992 RS
Engine: Carbed 350
OK - that makes sense.
Old Jun 15, 2010 | 08:44 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
thanks guys. just tryin to tie up some loose ends. this was my first swap. and i got murdered with this wiring. but now that its done. i have to find out why my SES light is on but i cant get communication to the ecm through the OBD hook up. im gonna try to get a new ecm and new custom prom and see what happens. if that doesnt work then im gonna buy a new wiring harness.
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
Ducati900ss
Sep 2, 2015 09:05 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
