Fuel pump won't stop running!
Old Jul 1, 2010 | 09:39 PM
AnotherWS6guy's Avatar
Car: 1987 Pontiac Trans Am STOLEN
Engine: 5.0L 4BBL Holley 650cfm Carb
Transmission: Stock 5-speed
Axle/Gears: Stock gears
I have an 89 Iroc with the 305 TBI. It was fine until I pulled the air filter housing and then the pump started running. It runs so much that I can hear it going thru the throttle body and back out the return line. It wont stop unless I unplug the battery. I pulled both fuses for the fuel pump and it keeps going. HELP
Old Jul 1, 2010 | 10:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel pump won't stop running!
Bad Oil Pressure Sending Unit (OPSU). The OPSU runs the pump when it 'sees' oil pressure - it can go bad in such a way that it 'thinks' it sees oil pressure when there is none. The OPSU has a direct uninterrupted connection to the battery, and a direct uninterrupted connection to the fuel pump. There is a fuse, tucked in the fenderwell behind the battery in a weatherpack - it will have one orange and one red wire running into it - you can remove that fuse and reconnect the battery - as long as the fuse is out the pump will not run. Put the fuse back in to make the pump run again. This will get you by without disconnecting the battery until you can get the OPSU replaced - just take the fuse out after driving and replace to drive again. The OPSU should be above the oil filter, about $35 to replace. It will have a 3 wire connector, one red wire, one orange wire, one other color (the other color is for the oil pressure guage, the red and orange are power in from battery and power out to the fuel pump.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
