Transmission switch now Speedo is not working
Old Jul 7, 2010 | 11:54 PM
viper23's Avatar
Car: 92 Camaro rs
Engine: Edelbrock 350
Transmission: TH 350
Axle/Gears: 373
I have a 92camaro rs which I just bought and it has had a tranmission swap to a turbo 350. It has also had an engine swap to a 350 crate edelbrock. Since this swap my gauges are not working. What do I have to do or buy to get it to work again. The only that works is my battery voltage and partially my gas gauge. I would really like my speedo and rpms back.
Old Jul 8, 2010 | 01:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Transmission switch now Speedo is not working
Originally Posted by viper23
Since this swap my gauges are not working. .
Were they working before?
Did you transfer over sensors from old engine?
Have you hooked up the correct wires for gauges?
TH350 only has a cable drive speedo and your dash is most likely electronic speedo
Old Jul 8, 2010 | 06:14 PM
Pocket's Avatar
Car: 91 Trans Am
Either swap to a large VSS tail housing to reuse your old VSS or use a cable to electric VSS adapter
Jorlain
Aug 24, 2022 05:11 PM
jhawkeye
May 25, 2022 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
milk
Aug 10, 2015 06:26 PM
beachrodder
Aug 7, 2015 04:27 PM
