guess that sensor!
Old Jul 24, 2010 | 03:10 AM
Jonnotjohn's Avatar
guess that sensor!
so i installed some k&n air filters and suddenly my vehicle is freaking out. sealing the crack in the airbox failed so now im wondering if its a faulty sensor. Its getting too much air and feeding too much fuel i think. the RPMs are at 2000 while in park and neutral and while in drive theyre at 1100 that sometimes fluctuates to the point of almost stalling. I took it to a local autozone to try and fegure out the trouble code but my 91 z28 is to old for them to do it for some reason...
91 camaro 5.0L V8 TPI.
any suggestions?
Old Jul 24, 2010 | 05:08 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: guess that sensor!
MAF sensor...did you oil that filter? MY buddies GTA bugged out likethat when he over oiled the filter and it jacked his sensor readings, had to replace his sensor but give it a shot with a normal filter and see if it helps, or no filter at all but dont drive it lol just test it out
Old Jul 24, 2010 | 06:00 AM
Jonnotjohn's Avatar
the MAF was my first guess until i realized it didnt have a MAF, 91's didnt have them. and yeah the filters actually came oiled
Old Jul 24, 2010 | 06:11 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Really? I thought they switched over to MAF later on in the generation.. I can't think of anything in line that'd get jacked up like that but I think the oil is your issue, I mean that's the last thing you did right?
Old Jul 24, 2010 | 06:33 AM
Jonnotjohn's Avatar
yeah it was after i put those in, it was fine for a day then started acting up. there isnt even a check engine light or anything
Old Jul 24, 2010 | 10:33 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Originally Posted by Jonnotjohn
I took it to a local autozone to try and fegure out the trouble code but my 91 z28 is to old for them to do it for some reason...:
You can pull your own codes with a paperclip:
https://www.thirdgen.org/service-eng...ht-error-codes
92firebirdguy
Sep 1, 2016 07:53 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Eric-86sc
Sep 7, 2015 02:10 PM
