Where to find this plug?
Old Aug 10, 2010 | 06:18 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Need to replace a plug for my exciter wire for my alternator. It's a 1 wire alternator but it uses a 4 pin plug.
Any idea where I could find this plug at?
Old Aug 11, 2010 | 12:06 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: Where to find this plug?
Have you tried your local GM dealer's parts dept???
PED = Packard Electric Division, part of Delphi who manufactures most if not all to the connectors used in our cars.
As noted, it is a 4 terminal connector, but it has 2 parts the male and the female connector. SFLP likely means Sealed Female ?? connector. Does it have a part number on it anywhere, such as 120xxxxx?
Old Aug 11, 2010 | 01:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Alternator terminal ID
Old Aug 12, 2010 | 11:07 PM
Look at www.rockauto.com
I looked at the 1989 5.7L engine parts and there are a few listings for this connector both under Voltage Regulator Connector and Alternator Control? Connector.
Cost is in the 10 - 17 dollar range plus shipping. I would think you would also be able to get an aftermarket connector at any other auto store. Most of the connectors of this type on rockauto, where I looked, are ACDelco parts, with a few aftermarket parts also listed.
eightsixseven
Dec 16, 2024 01:50 PM
Glowsock
Jan 9, 2017 04:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
