back up lights dont work in reverse
Old Sep 5, 2010 | 07:47 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
they come on a little ahead on reverse but when you lock it in gear they turn off is there any way to adjust the spot they come on?
Old Sep 5, 2010 | 08:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: back up lights dont work in reverse
Yes - your neutral safety switch needs adjusted. Take off center console top, on the right side of the shifter you'll see it - two screws hold it down - loosen and slide the switch on the screws a tad one direction or the other until the lights are on in Reverse - you can have the key ON and move the shifter while adjusting to get it right. Make sure park brake is on. Then make sure you still start in PARK and NEUTRAL after adjusting the reverse lights (because the switch won't allow start unless it's set right).
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
