headlights wont always come up
Old Sep 7, 2010 | 11:23 AM
burtreynoldss's Avatar
Car: 1989 Trans Am
Axle/Gears: 3:42
headlights will come on but not always flip up, i have 2 brand new headlight motors and a new headlight light switch, when i put the switch in i noticed the second prong had no where to plug into but just sat in an empty slot, i dont know if it fell out or its not supposed to be there, im lost help
Old Sep 7, 2010 | 12:21 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Playing Ping Prong
The prong that sends power to the lamps is the same one that sends power to the door module.
Because they open sometimes there is an intermittent connection which you need to find.
Wire up a small 12 volt bulb
(a side marker bulb works best).
Connect one lead to ground and the other lead to pin 1A
yellow wire on the module.
Make the wires long enuff to bring it into the cockpit.
The next time the doors don’t open observe if the bulb is illuminated.
If it is, you will know that control power is getting to the module therefore test or replace the module.
If the test bulb is not illuminated, you will know that control power is not getting to the module therefore you merely have to restore that one connection.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Sep 8, 2010 | 01:46 AM
Car: 1989 Trans Am
Axle/Gears: 3:42
Re: Playing Ping Prong
awsome ill give it a try, tonight they seemed to work almost every time, tryed them again when i got home and got nothing the first couple tries.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
