Device under coil? TPI
Old Sep 11, 2010 | 03:29 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So we are figuring out the wiring mess on my friends GTA and we found a device not connected with 2 air lines headed to the throttle body that is located under the ignition coil.
What is this device and any general info?
Old Sep 11, 2010 | 03:40 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Device under coil? TPI
Hello Carlos773!!
Sounds like you found the EGR solenoid!!
Fast355
Dec 2, 2016 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 5, 2015 11:02 PM
