Cluster Gauge Voltage
Old Sep 22, 2010 | 04:38 PM
Blue91ZConv's Avatar
Car: 1991 Z28 Conv.
Axle/Gears: Stock
For reference, I'm driving (yes, it's running now) a '91 Z28 (TPI)
This is a bit of a two part question...
1) Are the voltage levels that are read by the gauges coming from the computer, or directly from sensor data?
2) Is there any reference I can use to determine the proper calibration of any new or additional gauges?
Say I want to add a digital temperature gauge (not that I care to at this point). Is there a reference table (or book, or something) that can tell me that 2.0Vdc = 110 degrees???
From what I understand, everything (including the speedometer) on the gauge cluster is converted from a specific voltage level (0.5 - 5.0 Vdc for the speedometer)...
I was hoping that this was a standard value sent from the OBD1 computer, but am unsure at this point.
Thank you.
Old Sep 23, 2010 | 12:18 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
That Does Not Compute
From the sensors except the speedometer in some VINs.
You need to use external test instruments.
Say I want to add a digital temperature gauge ……. Is there a reference table (or book, or something) that can tell me that 2.0Vdc = 110 degrees?
When adding a digital temp gage, the sender comes with the unit.
Not if you’re referring to stock gages, they are analogue.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Sep 24, 2010 | 01:57 PM
Car: 1991 Z28 Conv.
Axle/Gears: Stock
Re: That Does Not Compute
What if I wanted to design my own gauge. How might I go about matching a specific resistance/voltage to the temperature of the engine? Are there no spec sheets anywhere on these sending units?
Old Sep 27, 2010 | 09:21 AM
NINÅ's Avatar
Transmission: 765R4
It’s A Thermistor Mister
You won’t be able to find specifications for the sending units other than resistance at a few temperature levels.
However you can plot the graph yourself VIA putting a unit in water, then heating the water while monitoring the temperature with a test instrument quality thermometer and ohmmeter.
Or, you can get a thermistor from an electronics supply house where the thermistor comes with a data sheet.
You can install the thermistor in a brass housing threaded to fit the engine.
Happy Racing!
I Didn’t Wreck, The Track Moved
eustodp
Sep 20, 2015 05:09 PM
codeysabatini
Sep 20, 2015 11:36 AM
CatmanFS
Sep 19, 2015 09:00 AM
TrevinE
Sep 14, 2015 03:20 PM
90formulaVortec
Sep 8, 2015 12:42 AM
