sidemarker/blinker help
Old Sep 28, 2010 | 08:58 AM
infared337's Avatar
My drivers side side markers and blinkers are
Not working is it a relay or fuse or what? The fuse under the dash is ok and headlights work any suggestions also the passenger side lights work fine. I also noticed that my interior light is not coming on when i open the drivers door. this all happened at the same time. any help would be appreciated.....i just got over the vats issue...then the car got hit..got it back then a brake line needed replaced. now this...lol i just want to drive it at least one week before the weather changes here in Kansas
Old Sep 28, 2010 | 10:48 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It Doesn’t Blink, Therefore I Think……..
Because the right side works you know the fuse is good.
With the key in
RUN, turn signal stalk in the left turn position, use a test light to probe the light blue wire out of the turn signal switch.
Is there power there?
If not, replace the switch.
If there is power there, make sure it gets in and out of the connector located near the lower right of the steering column.
Then make sure power gets in and out of the large connector located near the left front of the dash below the relay bracket.
From there it goes to the lamps on the front of the car.
my interior light is not coming on when i open the (left) door.
If the right door turns on the interior lights the problem is the pin switch in the left door, or the wiring going to it has a broken connection.
Just trace it till you find the bad connection.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Sep 28, 2010 | 08:10 PM
infared337's Avatar
Re: sidemarker/blinker help
Ok thanks for the help. I had a chance to play with it a bit more today I ran a test light to the parklamp connectors with the bulbs removed. I have power to both sides. I did not test the sidemarkers. Ok here's where it gets funny if I turn on the hazards the lights work with the exception of the side mareker. Any ideas
Old Sep 29, 2010 | 01:55 PM
NINÅ's Avatar
Transmission: 765R4
The Hazards working properly, but the left turn signal not, is consistent with a defective turn signal switch or the connection to it.
However fix the side marker first to avoid unnecessary parts replacement.
Make sure the side marker socket has good connections to it.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
