helppp me woth headlights
Old Sep 28, 2010 | 11:51 AM
darkness878's Avatar
Car: 1987 iroc z camaro
Transmission: 700 r4
Axle/Gears: no idea
i somehow fried my whole headlight switch in my 87 iroc i have the nut and shaft and **** off the switch is just back in the dash still how do i get it out without ripping the whole dash off
Old Sep 28, 2010 | 01:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
M•m•m•m•m Delicious Fried Lightswitch
There's a spring loaded button on the side of the switch.
Push that in and you can pull the **** out.
That should give you access to a nut that holds it on the dash.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Sep 28, 2010 | 07:34 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: helppp me woth headlights
You can get to it either by removing the panel under the dash right above your knees or by removing the gauge cluster. As long as the shaft is out and the plastic nut that holds it against the dash are out, you can unplug the switch and get it out. Repeat steps in reverse to replace.
Old Oct 4, 2010 | 09:15 PM
Axle/Gears: no idea
i got it all out and working now when i turn my headlights on no dah lights everything else works but when i put a fuse in the place where it should be and put the dimmer all the way on it starts to smoke
Old Oct 4, 2010 | 09:20 PM
bubbgoose's Avatar
I dont have any information that would help but I replaced the headlight switch in mine and it caused all of the same problems you have.
Old Oct 4, 2010 | 09:35 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sounds like there is a problem that fried your original switch and now it's doing in the new one. Have you upgraded your headlights at all? Any lights acting up before your first switch went out?? Maybe bad grounds? I really have no idea, but there are lots of electrically knowledgeable folks on here that do
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
