SCHEMATIC help needed for Fuel Pump
Old Sep 28, 2010 | 03:58 PM
S-chargedIroc's Avatar
Car: 1987 IROC Z
Engine: L98 350
I have a 1987 Camaro IROC Z with the L98 350 TPI motor. I am rewiring the wire harness to a relay i purcased. Can someone PLEASE if you know for certain tell me which wire is which. There are three from the Pump: A black wire, a pink wire, and a tan wire. I cannnot get the car running properly without knowing for sure and i am in a huge bind to get the car out of my driveway. All help is greatly appreciated...
Old Sep 28, 2010 | 08:32 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: SCHEMATIC help needed for Fuel Pump
Black = ground
Pink = gauge
Tan = pump
To verify just hook up ground and run a 'live' 12 volt jumper wire to the tan wire. You should hear the pump kick on until jumper wire is removed.
Old Sep 29, 2010 | 10:38 AM
Car: 1987 IROC Z
Engine: L98 350
Thankyou so much for your help. You were exactly correct and I was able to put the pump to a Relay and switch...
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
