Need Help Please!
Old Oct 5, 2010 | 01:34 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Need Help Please!
1. Does anyone make heavy duty headlight kits? I'd like to convert to a more modern style headlight setup so i can turn a switch an it will activate a relay to turn the headlights &or markers with no issue.
2. Does anyone know what would be a better headlight switch to convert too? Our stock one takes on the load which isn't such a brilliant idea.. I'd like to make it to a more modern switch 3-4way switch. Take one from a 00+ silverado or something?
Old Oct 5, 2010 | 04:31 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: Need Help Please!
You don't have to convert unless you just absolutely want to. You can use the factory switch and not effect the load if you use a relay to power them AFTER the switch.
Old Oct 6, 2010 | 03:04 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
My stock switch is starting to hit the *******, for the interior lighting part. So i was wanting to do a conversion.
