Door wiring
Old Oct 12, 2010 | 07:21 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Door wiring
So, while disaasmebling my 1991 Z28, I let my buddy tackle the doors, while I got the rear bumper. He decided to be lazy, instead of spending two minutes taking the things off the doors and pulling the wiring out, he chopped it right by the rubber protectors at the front of the door, on both doors. God*mmit. I about ripped his head off. Is the door wiring a seperate harness? Or a part of the general harness for the interior? How can I fix this cheaply???
One last question, behind the passenger fender, where that mess of wires comes out, there is an orange one that is chopped in half... What is that wire for?
Old Oct 12, 2010 | 07:39 PM
Drew's Avatar
Re: Door wiring
Late cars the door harnesses are hardwired together... The harness is one piece from the switches all the way to both doors. It sucks because some early cars have a connection just inside the body where they can be disconnected.
Solid orange is constant 12v+ it goes all over the car for different purposes.
Old Oct 12, 2010 | 07:54 PM
Engine: M54 DOHC I6
Axle/Gears: Stock
Re: Door wiring
Thanks for that info! Any reason as to why someone would chop that wire? Everything seemed to work on it, except the hatch motor. How would you go about fixing the door wiring?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
g.l.mos
Aug 22, 2015 12:02 AM
BlackTopKing
Aug 19, 2015 12:13 PM
