Speedometer Questions
Old Oct 26, 2010 | 05:38 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Hey guys, just to confirm, my 1987 Camaro v6 5-speed Sport Coupe has a mechanical speedo right?
Then, how easy is it to convert my mechanical speedometer, to an electric one?
I want to get all electric Autometer Phantom gauges and need any info on how to do so.
Thanks guys.
Old Oct 28, 2010 | 03:30 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
Re: Speedometer Questions
my 87 auto doesn't look to have a cable going to the back of the instrument cluster. My speed sensor only has the electrical two wires coming out of it. Would a mechanical have the cable coming out of the speed sensor as well as the electrical?
Old Oct 28, 2010 | 04:05 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I am doing a conversion from my auto to a 5spd. All you have to do is find a elec speedo from a 90? or newer car and and it will bolt right into your housing. I am sure you can buy the elec speedo sender, but the gear from what I understand is the hard part to track down cause it is different from the mechanical version. I had to get a mechanical drive with gear out of the yard for mine.
Oh and no, the two do not come in the same housing on the newer ones. All it is is a plug for an elec connector. Early cars used an elec conversion off the back of the speedo for computer stuff.
Old Oct 28, 2010 | 04:10 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Firebirds got the electric from 87-92
Camaro from 90-92
you will need a box that converts the signal to digital... or something... I don't remember, but I'll do a search for you...
Old Oct 28, 2010 | 04:14 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
http://www.hawksthirdgenparts.com/er...nsmission.aspx
or you might be able to replace the speedo gear with an electric one... don't know though..
Old Oct 30, 2010 | 04:37 PM
nezzie09's Avatar
Engine: 2.8 MPFI
Camaro from 90-92
Thanks man
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
