Keyless Hatch entry?
Car: 85 Z28
Engine: 327
I have a 85 camaro and the PO decided that they needed to get into the hatch without a key. In the process they mangled the metal that goes around the lock cylinder. I want to just fill in the mangled hole and was curious if anybody has installed some sort of keyless device to pop the hatch from outside?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Keyless Hatch entry?
My car has keyless entry installed, but the PO did it, not me. Looks pretty simple, a small controller sits under the dash pad, wires running to the door lock circuits (I have power doors) and to the hatch release button (I have motorized hatch pulldown), and a 3 button fob (lock, unlock, hatch).
I wired my GM alarm to pop the hatch, no need to add anything, just wire it into the release motor relay.
http://cgi.ebay.com/ebaymotors/GM-CA...#ht_1816wt_939
I have that. Looks totally factory, I like that it is OEM GM and it comes w/ instruction.
When you set it up you can use the additional button for whatever you want. I have it set for the hatch. Simply hold it a couple secs to open. All you need to do is wire the ground trigger so that it triggers the release solenoid relay under the center console. It's easy as that.
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
