Power door lock switch type.
Old Nov 15, 2010 | 08:03 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I got a power window and door lock set up but I have an issue with the door lock switches. Not electrical but with the switch itself. The switch is mounted in a 2 x 3.5 inch trim plate but my door panel has a horizontal hole 1/2 inch x 1.5 inches. I looks like it should use a switch like the window switches but I can't find a lock switch anywhere so far that looks correct. Every one I've seen is the same as the one that goes in the larger plate and that doesn't look like it fits what I've got. It's a 91 Firebird with a grey interior. Anyone know where to find the correct lock switch?
Old Nov 15, 2010 | 08:20 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Power door lock switch type.
Standard Motor Products - part# DS1424. Any auto parts store can get it.
Old Nov 16, 2010 | 03:12 PM
Drew's Avatar
Camaros and early Firebirds have a large bezel that the lock switch snaps into. Later Firebirds the bezel doubles as the door handle cup and locates the lock switch. The switch is the same all the way from 82-92 in both the Camaro and the Firebird, the only difference is 90-up Camaros have yellow lettering.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
