need help with lights
Old Nov 17, 2010 | 09:39 PM
demonbooger's Avatar
Car: 84 berlinetta
Engine: mod 305
Transmission: m5 i think
Axle/Gears: stock
all my lights work except my headlights and the passenger side marker light, and the reverse lights are allways on . when i press the button to turn the lights on i hear it click in the ecu but nothing happens. i checked the connections and everything is pluged . fueses are good . do the headlights run in a circuit (if one goes out they all go out like xmas lights) causing all of them to fault including the reverse lights .help me out somebody
Old Nov 17, 2010 | 10:48 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: need help with lights
Well first off, the headlights have nothing to do with the ECU. They're just a simple bulb and electricity system. One light going out would not cause all of them to fail. It would be illegal to manufacture a car like that. The second thing that has me concerned is that you said when you "Press the button". The headlights are operated by a **** you pull out (Firebird owners correct me if I am wrong but I own a Camaro). The passenger side marker light could be as simple as a blown bulb, but I'll assume you've checked that already. If the fuses are all good, and you are positive the switch isn't bad, It's time to start tracing wires and make sure nothing got hacked.
As for the reverse lights always being on, There is a switch on the shifter that turns the reverse lights on and off. Check here first. Or it could also be that the same joker who hacked the headlights screwed up the reverse lights, too.
Old Nov 18, 2010 | 09:32 AM
moogs's Avatar
i have a 1984 camaro berlinetta and my headlights won't turn on sometimes and if they do they will randomly turn on and off i've been looking for new wiring harnesses and other electronics to replace on my car but i ahven't found any place to get them and body have any ideas where i can find any or wut to do to fix the problem
Old Nov 18, 2010 | 10:59 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you wont be able to find the harnesses/wiring new, so you'll have to trace out whats in the car now. luckily, there's one harness for all the front lighting and its comes from the driver side (C100, smaller driver-most half). I'd take a look at the diagrams here and begin testing for connectivity; these cars are getting older and you could have a broken wire, loose connection, or any number of things. If all the wiring tests out good, you may have a bad switch in the dash
Old Nov 18, 2010 | 11:14 AM
moogs's Avatar
this may be sosemthing ur not sure bout but is there a place i could call to get a custom harness made cause i'm jsut trying to redo all my wiring
Old Nov 18, 2010 | 11:22 AM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hi moogs, here i found this headlight harness for your 84 camaro. I am pretty sure it is the one you need. Maybe one of the pros here can comment,
http://cgi.ebay.ca/82-84-Chevy-Camar...item518817ddb0
onthedownlow
Old Nov 18, 2010 | 11:26 AM
moogs's Avatar
thx alot since i'll prob get that ordered and does any one know where i can get the the pods for the 84 berlinettas
Old Nov 18, 2010 | 12:01 PM
Engine: 355
yeah here's a link to one of our members sites, he is a stand up guy and carries a lot of berlinetta goodies,
http://www.berlinetta.info/electron.htm
Old Nov 18, 2010 | 12:03 PM
Engine: 355
you did mean the interior control pods right?? I was just thinking...maybe he meant the headlight pods....anyhoo hope I was of some help.
Old Nov 18, 2010 | 12:07 PM
moogs's Avatar
ya i meant control pods and i've email that guy but i've never got a response form him
Old Nov 18, 2010 | 12:14 PM
Engine: 355
hmm, I have bought off the guy in the past, not sure whats up there... well good luck to you moogs. Google is an amazing tool and there is no part you cannot find using it. Try googling camaro berlinetta wiper pod and if that doesn't work try another variation of it, alot of times you will find killer deals this way too.
onthedownlow
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
