87 TA fuel pump not working
Old Nov 24, 2010 | 09:30 AM
my87_5spgta's Avatar
I have had my Ta sitting for awhile now.I would say about 6 to 8 months.
when i left it everything was working. I now have afuel pump problem. I checked the fues and relays.I have power going to the relay on the firewall and power going to the fuse near the front fender.Anything else to check before thinking the fuel pump is the problem?ugh ugh ugh!
Old Nov 24, 2010 | 10:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 87 TA fuel pump not working
if the pump doesn't run during crank, it's probably shot. even if the relay tanks, tho ops will run the fp once oil pressure exceeds 4psi.
gas easily turns to crap in that time w/o stabilizer and can gum up a pump. i've had it happen before to a new pump. luck of the draw sometimes.
does the relay 'tick' for key on engine off (koeo) ? should tick ko (fp prime) and tick again 2sec later (fp off waiting for start).
Old Nov 25, 2010 | 09:19 AM
Yes, i hear a the click form the relay when i turn the key then one after a few secs....Ugh went from the car running great to nothing just by sitting. So what a job this will be rt..lol
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
