Quick pop-up headlight help?
Old Nov 27, 2010 | 07:02 PM
Flightoficarus's Avatar
So I finally got around to replacing my broken drivers side headlamp assembly on the 'bird. I have it installed, and everything, but it seems like I still need to make a few adjustments, because it doesn't seem to align up w/the body perfectly like the other light does. I'm done messing around with it today since it's cold and crappy out, but is it possible I need rescrew/tighten the mounting bolts better? or what about the headlamp adjustment screws? or does that only change the headlamp's aim? Help appreciated!
P.S: I have measured the new assembly, and the dimensions are the same as the old one.
Old Nov 28, 2010 | 01:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Quick pop-up headlight help?
It's been a bit since I've messed with mine but, there are 4 brackets (adjustable) that hold the assembly to the radiator support and the lid itself has a slight bit of adjustment (not much). It's just a matter of taking your time and moving it around until it lines up the way you want it to. It's more a 'body' question than it is 'electronics'.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
