how to test if map wiring is good.
Old Nov 30, 2010 | 11:27 PM
SpeedoDeedo's Avatar
Got a code 33 and replaced map want to see if the wiring from the map to the ecm is good. What would be a good way to do it?
Cars is a 91 rs 3.1
Old Dec 1, 2010 | 11:01 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: how to test if map wiring is good.
If you do a Google search there are pictures and instructions. You'll need a 5v dc power supply, a digital volt meter and a vacuum pump. I use the usb port on a pc as the 5volt supply. Just identify which is +ve and -ve. I got an un-needed usb cable and cut the end off and stripped the wires. By applying a given vacuum to the map you can measure the change in output voltage from the map. Again the values are with the instructions. I'll try to find the link again.
Old Dec 2, 2010 | 09:40 PM
Pocket's Avatar
Car: 91 Trans Am
Do a resistance check from the connector terminals to the ECM. Anything higher than 1.5ohms is a problem
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
