speedo/odemeter SES light???
Old Dec 6, 2010 | 09:24 PM
Webmouth247's Avatar
Car: 89 iroc-z
Engine: 5.7 tpi
Transmission: soon to be t56
got a 89 5.7 tpi with a t-56 swap. i had the tail shaft converted to read the mechanical speedo. so im not running a black box or anything other than stock.
Cable was bouncy and made a wierd noise. Today noise stoped but so did my speedometer and odometer. Alil down the road the SES light pops on. Turn the car off... turn back on and drive... speedo/odo still not working and SES turns off... get about a mile down the road and the SES turns back on. Car runs fine with no other issues. Can someone give me some direction on what i should do? Thanks in advance.
Old Dec 7, 2010 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo/odemeter SES light???
Sounds like the cable isn't turning (the light is probably a code 24). At any rate, check the following for some ideas:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Dec 7, 2010 | 09:23 PM
Car: 89 iroc-z
Engine: 5.7 tpi
thanks james but would this cause my SES light to turn on?
Old Dec 7, 2010 | 11:42 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
yes,because the ECM will not be getting a VSS signal.
No VSS signal might also cause some minor drivabilty
problems.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
