89 camaro gauge keeps blowing fuse
Car: 89 camaro
Engine: 305tbi
Transmission: 5 speed manul
i have an 89 camaro that keeps blowing the fuse for the gauge you put one in and as soon as you turn on key it blows but when you turn park lights on the temp and the oil pressure gauge will move we have replace the egr and i worked for about a day
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: 89 camaro gauge keeps blowing fuse
Very easy!!! You have a short. You'll have to find a wiring diagram as a reference. Then fron the fuse box, follow the wire from point a (fusebox) to point b. You have bare wire exposed and its grounding itself out. Trace both wires that are associated with that fuse.
Ghettobird52
Jul 5, 2024 11:18 PM
